Hello, the design importer in A13 OneLander WP theme is rejecting my valid purchase code, same code used to sign up for this support forum.
I reported this via the TF comment thread and was told that it's possibly due to issue with Envato API redirecting to https, and I changed the envy.php file as suggested but problem remains.
Please advise what to do now as I need to import the demo.
If change in code didn't help I think I will have to take a look on your installation.
Could you please send me temporary access to your WordPress and FTP so I could check there what is going on? Send it here on forum via private message(click on my nick, in top-right corner you will find option "Message"). In message please add LINK to topic it applies to.
Thanks for help with this.
It was issue with timeout of connection. There was 5 second time for server to connect to license server, and for some reason it wasn't enough in your case. So I have changed it to 30 seconds and code got verified fine :-)
I will add same fix to next update.
Big thanks for help!
