Hello
Still loving your templates but ran across a new couple new issues.
1. Menu overlay
a) I'm using the menu overlay combined with a onePage navigation. the menu works but the overlay doesn't go away on click and there fore you have to click the overlay awy to see the content.
b) Some of the onepage menu rows, still go hiding below the header instead of starting right below the header.. any way of solving this?
2. Styling the contact form
While css makes the background changes fine the text of the imputs fields doesn't react to my code (see screenshot). For some reason the dropdown menu text does react to the same code...
Thanks for your precious help!
Pascal
I believe these are placeholders. When you will enter text there it will be black, as you want. It is good to have placeholders in a different color than text.
For the menu overlay that would be great if it could be solved as my client really wishes no "classic menu" Where is that "hide after selecting menu" option being set?
Thanks for the setting proposal for the sticky header variant.. I will use this!
For the contact form: yes theres are placeholders. But In their preset color version I don't like the color so I'd like to be able to stylize these texts to the color of my choice.. any thoughts on that?
Pascal
I am working now on some tweaks for GDPR, so in few(10 at max) days update will be released, as We have released update just yesterday.
For placeholders you can try CSS from this answer https://stackoverflow.com/a/2610741
You can prefix it with
.wpcf7
class.With kind regards.
Such small correction.
The CSS for the placeholder works like a charm.
I didn't realize that was just for the mobile menu.. that is set already! But as you said it should also work on desktop.. so I'm looking forward to that update (also concerning the tweaks for GDPR)
Thanks, Pascal
