I've created a onpage website within the Chillout II theme. Everything works fine, however, the 'Close mobile menu after click' option does not work. That is, after selecting a menu item on the mobile website the menu does not close but has to be closed by another click on the 'X'.
I have just tested and it works on my installations, so I suspect it can be something in your installation. Could you send me a link to your site?
http://35.204.51.56
I thought it could as well be connected to the tested device but it's not working on iOS device nor in the emulated mobile view.
I believe it can be caused by one of your plugins, as I see it also is attaching events to this menu items and might be blocking theme events.
Probably jquery smooth scroll, but not 100% sure.
The theme has built-in smooth scroll so it might come in conflict. If it is not this, try disabling other plugins.
Thanks a lot!!
