Hi Support Team,
I am seeing when i try to post comments and click on "Submit Comments" button , it doesn't get submit on the first click and i have to click twice then the comments get submit to the blog.
i have seen the same thing on your demo too , can we fix it
this is one of my website blog post:
http://www.urecomm.com/pandora-jewelery-luxury-jewelery-with-a-personal-touch
I am sorry to say but we don't longer support or develop Airborn. This bug is connected with JavaScript form validation. Shame no one noticed it earlier:-/
With kindly regards.
You could try to edit airborn/common/js/scripts.js in line ~301 and change this code
if($(this).hasClass('validated')){
return true;
else{
e.preventDefault();
error_number = 0;
$(this).find('input.required, textarea').each(function(){
if( $.trim( $(this).val() ) == '' ){
$(this).parent().addClass('error');
error_number++;
return;
if( $(this).hasClass('email') ){
var emailRegEx = /^[A-Z0-9._%+-]+@[A-Z0-9.-]+\.[A-Z]{2,4}$/i;
// alert($(this).val() + ' ' + $(this).val().search(emailRegEx));
if ($(this).val().search(emailRegEx) == -1) {
error_number++;
return;
// everythin ok
$(this).parent().removeClass('error');
if( error_number == 0 ){
if( $('#url').val() == $('#url').attr('title') ){
$('#url').val('');
$(this).addClass('validated').submit();
to
when i changed it , it disturb images on post
i have replaced exact the same codes
}and whole JavaScript broken.Check carefully.
