Comments not getting submit at once
edited November 2012 in Airborn Posts: 10
Hi Support Team,
I am seeing when i try to post comments and click on "Submit Comments" button , it doesn't get submit on the first click and i have to click twice then the comments get submit to the blog.
i have seen the same thing on your demo too , can we fix it
this is one of my website blog post: http://www.urecomm.com/pandora-jewelery-luxury-jewelery-with-a-personal-touch
    Hello aamir.
    I am sorry to say but we don't longer support or develop Airborn. This bug is connected with JavaScript form validation. Shame no one noticed it earlier:-/
    With kindly regards.
    You could try to edit airborn/common/js/scripts.js in line ~301 and change this code
    if($(this).hasClass('validated')){
                    return true;
                else{
                    e.preventDefault();
                    error_number = 0;
                    $(this).find('input.required, textarea').each(function(){
                        if( $.trim( $(this).val() ) == '' ){
                            $(this).parent().addClass('error');
                            error_number++;
                            return;
                        if( $(this).hasClass('email') ){
                            var emailRegEx = /^[A-Z0-9._%+-]+@[A-Z0-9.-]+\.[A-Z]{2,4}$/i;
    //                        alert($(this).val() + ' ' + $(this).val().search(emailRegEx));
                             if ($(this).val().search(emailRegEx) == -1) {
                                error_number++;
                                return;
                        // everythin ok
                        $(this).parent().removeClass('error');
                    if( error_number == 0 ){
                        if( $('#url').val() == $('#url').attr('title') ){
                            $('#url').val('');
                        $(this).addClass('validated').submit();
    to
    error_number = 0;
                        error_number++;
                        return;
                            error_number++;
                            return;
                    // everythin ok
                        $('#url').val('');
                else{
                    e.preventDefault();
    No :(
    when i changed it , it disturb images on post
    i have replaced exact the same codes
    Images? Then you must did something wrong, probably ate one of } and whole JavaScript broken.
    Check carefully.
