I am pitching a client to switch from another theme (WP Bakery bundled) to Rife.
But we need to make sure can they achieve this effect as follows:
(1) A PAGE or Portfolio Page Grid (NOT POST) from a set of selected Pages
(2) With Title and Overlay across each Page Grid items and when clicked upon....
(3) Open up a "Light Box/Popup" of the Page Selected with where they can scroll with clickable link on them.
You can refer to the attached screen shot on to the following link to see what I mean...
Https://cl.ly/4312373f3K2DCheers
Jason S
Right now we have the option to show works in the lightbox, here you can see how it works: https://rifetheme.com/chillout2/#works
There is only one restriction there, you can't add content from the Elementor and you can use only the default WordPress editor.
You can enable this option here: http://nimb.ws/f5SNQC
Best Regards
Will play around with this a little. Any chance you guys will be working on enabling the elementor features for this or does elementor pro or any addon/plugins can do this off the shelf?
Cheer
Jason S
It will require to fire them again manually. And the tricky part is to know which one to fire and how.
I will look into this(Putting it in kilometer long TODO list).
No worry, I will figure other way around to pitch my client.
In the mean time, I just found a plugin that seems to do this.
Here's the link: https://www.dynamic.ooo/demo/ajax-page/
Maybe you can use it as a reference in the future.....(after that
"Light Years" long To Do List of yours.)
Cheers
Jason S
It is rather simple as our "works in lightbox". It just has a widget in Elementor instead of our shortcode for post grid.
Still, if you like it that is good :-)
Yes, you are right. After further research, that plugin other than having a widget in Elementor, is also limited like your shortcode, where the POP UP page does not support ELementor Build page but regular theme page.
Guess this will be a dead end then.
But just wondering, what if we use Revo Slider to build that PoP up page instead?
Tell me what you think?
Cheers
Jason S
If it is loaded by AJAX then I suppose it will not.
As I said before, Elementor actions in such case have to be triggered manually. It would be easier if Elementor wouldn't evolve all the time :-)
Thanks for your answer and your patience.
I am not simply not "Tech Savvy" enough to grasps everything you told me.
I must LEARN More.
Jason S
I believe it is possible to make Elementor work in "lightbox content" loaded dynamically by AJAX, but I am afraid it will be a fragile solution(cause of constant changes in Elementor updates). This could cause unnecessary frustration among users and hate towards solution implementor(me ).
However, I am open to taking the challenge, just need to solve other things currently, so I will not be able to match with your schedule and give you a solution while you need it :-)
