How can we remove the BLOG page title?
https://brittyrose.com/blog/ I can't find any setting/option for designed Blog page title on/off
Pls let me know THNKS! #RIFEROCKS
  • I figured it out, but when remove there is no option to increase padding under header and above post list. I think we are ok as is once I removed padding around Blog title (attached) and added theme color. She is adding a second blog post today so it will be balanced. In the future, if Blog title is removed, is there a way to add padding so header and posts images don't overlap? BIG UPS!!
    1237 x 788 - 421K
    1402 x 679 - 516K
    Hey WebStylist :-)
    To disable title-bar you can do it in Customizing ▸ Blog settings ▸ Posts list - title bar
    TheWebStylist said: In the future, if Blog title is removed, is there a way to add padding so header and posts images don't overlap?
    Not padding, but you can enable option that will not put content under header.
    Go to Customizing ▸ Blog settings ▸ Posts list ▸ Hide content under header and you will be fine then :-)
  • Ahhh GRT thanks sir Air!
