Hello, I am trying to use albums as featured products on my sites home page. This seems to work fine except the featured image looks blurry on the actual page. Is there a setting to change what pixel size the album images should be? The same images look great as products. Not sure the cause for the loss of quality when the same file is used as an album.
Please advise and thank you!
Basically the slider is normal when there is nothing else on the page. When I add the albums to the page the slider gets much larger spanning the entire width of the page. How can I make sure the slider doesn't change when adding the albums?
I don't think I understand. Could you give more details?
Albums list is template only for listing all albums( https://rifetheme.com/help/docs/content-management/albums-works-post-types/adding-albums-list/ ), and shouldn't be used for normal pages.
If you are making a normal page, use the default template.
