Hi Air,
I've had a look in the documentation and searched other posts but can't find anything that seems to answer this question exactly - please do point me in the right direction if this is answered already...
When I type my website name into Messenger in Facebook or in Facebook, as well as the image of the logo, underneath the name I get a caption.
I can't find where to change this in the theme, so that this doesn't show up. or that it says something more meaningful, like Lightning in a Bottle Productions or anything else I choose.
I can't find this text anywhere - been looking in Header, also logo, also searching in the Media, but no luck.
Sorry if it's obvious, but how can I tidy this up?
Thanks,
Heather
You use Album as your homepage and in Album there is no much text info that Facebook can use.
For this, best is use SEO plugin, that allows you to add specific information for services like Facebook or Twitter.
I can recommend Yoast SEO https://rifetheme.com/help/docs/plugins-recommendations/yoast-seo/
After activation, configure all its options and then go to edit album on that you use as your front-page and there in this plugin metabox options set all your info.
Follow this for help https://kb.yoast.com/kb/custom-open-graph-tags/
Still, there is a cache on FaceBook, so you might not see a difference immediately, but you can always use this link to clear facebook cache for your page https://developers.facebook.com/tools/debug/sharing/?q=https://lightninginabottle.co.uk/
Hope this helps.
WIth kind regards.
