I see that Essential Elementor addons plugin is using the same class as our theme header, and it is affecting how the theme header works.
I think I will have to rename this class for the next version. It will be a pretty big change for some users.
Please disable this plugin while customizing the header and logo to see proper results.
About logo: I would say that 200px wide logo is enough. So upload a smaller version of your current logo, instead of this over 1200px wide one :-)
MyMetta said: it needs to be on the far left and aligned with the menu items - see dev site
You have enabled narrow header option. Go to Appearance → Customize → Header Settings → Type, variant, background → Content width and set it to Full width.
Please can you confirm recommended logo size thanks - sent an email with dev site
About logo:
I would say that 200px wide logo is enough. So upload a smaller version of your current logo, instead of this over 1200px wide one :-) You have enabled narrow header option. Go to Appearance → Customize → Header Settings → Type, variant, background → Content width and set it to Full width.
Hope this will answer your question.
