touchstart
click
document.addEventListener("touchstart", function(){}, true);
It seems that on Android devices both themes work the same.
However, on iOS there is a difference like you have said.
I have spent an hour trying to find the difference but I don't have an answer yet.
I will reply as soon as I will find out anything.
In Photon we have reacted to
touchstart
andclick
events, while in Rife we only useclick
, astouchstart
have some drawbacks.However, it looks that for iOS it is enough to add even empty listner on
touchstart
to activate hover on touching.If you are familiar with adding custom JavaScript, then you can add this code to fix it:
If not, then it will be added in the next update.
Big thanks for asking about this - I have learned something new :-)
