Hi Air
It's been a while! But after updating my site to Fatmoon 2.2.0 I experience a weird behavior in my "works". It is supposed to be full screen but now has a empty space on the right side. Also the resizing seem to be acting strange.. just the right row start rezising and getting smaller until a row change occurs.. look for yourself:
https://flyart.com/work/various-logo-designs/Thanks for your help!
Pascal
Yes it could be it, start with renaming this file on the server to _single-work.php to disable it affecting the theme.
If that fixes the issue, you will have to update your file in the child theme.
Thanks for your reply! YOu are right.. it's the single-work.php file that does this. You helped me with that to have the text place above the image grid which I still need.. could you have a look a the php file to see how it could be solved?
thanks a lot
Pascal
Please try file from attached zip.
Thanks a lot.. unfortunately now all I get when I click a single work is a blank page ( see for example: https://flyart.com/work/various-logo-designs/ )
There are some things in that file that are from upcoming 2.3.0 version, and now it is making PHP error on your website.
In this file in line 29 remove all this code
<?php apollo13framework_schema_args('creative'); ?>With kind regards.
Should I keep your version for the upcoming 2.3.0 to remain compatible?
