Socials Shortcode Colour on hover
in Rife Posts: 87
Hi
I am using the shortcode to show social icons in footer - I have added a custom colour to the shortcode but I guess this is not how to do it!
Is there a shortcode way to have white active and custom color on hover please?
    Unfortunately, all colors are predefined in CSS.
    If you don't like our colors when you set "color" option for hover, I can help you with custom CSS.
    For that, set "white" value for hover param and add this custom CSS:
    .socials.icons-only.white_hover a:hover{
    	color: #fff; /* your color */
    Hi - thanks - I tried this in CSS file and customizer - no change. Its not the end of the world.
    I guess it has to go somewhere in Elementor? Im using an elementor widget in Footer Column 1
    thanks
    Air said: For that, set "white" value for hover param
    This is what you are missing.
    Hi - thanks
    I want white on display and a custom colour for hover so not sure why i would set white for hover??
    This is my CSS - set in customizer and style file but I am using an elementor section template that has a shortcode plus the image box..thanks
    color: #ee990e
    MyMetta said: I want white on display and a custom colour for hover so not sure why i would set white for hover??
    Could you just do it? :-)
    "white" in this situation is a parameter that sets class white_hover that I have given you CSS for. Your CSS will start to work once you will follow instructions to the end.
