MyMetta said: hope you're well.
Template: rife
You want to change the name in the admin panel, or URLs in source code?
If later, then rename child theme directory - it is not updated. You will have to reactivate it after renaming.
You will have to rename the main theme as well then, and probably in style.css of the child theme, change
Template: rifeto your new name.I am not sure how it affects updates, but I suppose you will have to update manually after such change.
