Change Child Theme Name
in Rife Posts: 87
HI Guys hope you're well.
Whats your recommended way to change the child theme name and still be able to get updates.
e.g. child theme is rife child pro and I want it to be mytheme
Many Thanks :)
    MyMetta said: hope you're well.
    Thanks, we are trying to be ;-)
    You want to change the name in the admin panel, or URLs in source code?
    If later, then rename child theme directory - it is not updated. You will have to reactivate it after renaming.
    Hey - URL in source code if possible - I still need to update the parent..thanks
    You will have to rename the main theme as well then, and probably in style.css of the child theme, change Template: rife to your new name.
    I am not sure how it affects updates, but I suppose you will have to update manually after such change.
