Our site started behaving strange. Loading then blacking out. Having deactivated all the plugins and reactivated one by one it is Elementor that is causing the problem.
However having built the site with Elementor and OneLander I'm struggling to fix it.
Help please
Does it happen on every browser machine that you test, or only on yours?
Please check the private message, and after this is solved, I will take a look into your installation.
Thanks for the data!
Please start by increasing your PHP version to 7.X. If this will not help, I will look further at what could be wrong.
1. Can I update the theme to the newest version, or you did some changes in it?
2. Could you explain in more details or by screenshot what you mean by "Loading then blacking out."?
2. It's currently behind a maintenance plugin because of the problems and the need to take bookings. http://www.sondertruro.co.uk/wp-content/uploads/screen.mov
OK, I don't see ANY images on your website because of this error: Failed to load resource: net::ERR_CERT_DATE_INVALID
It seems your SSL got outdated but still some files are served from https. DO you plan to renew your SSL?
OK, I have update theme on your website.
I have also updated all https images, except for burger.jpg - you will have to find it in Elementor.
I have disable other plugins for now. Please check your webiste is it better now.
I don't see anything as on your movie happening right now, but please verify this.
In then end non of this was connected to theme, but hope I was helpful.
