I have installed the Fatmoon template in a Wordpress 5.0.2 . That you recommend me to do. I was able to update WPBakery to the latest version. What I do?
Please read the last comment from .Air, he wrote that: "I will not be able to release an (WPBakery) update before January, as I am in the middle of work on version 2.3.0"
Eso lo he leído pero tambien he leído que si urge hay opción de enviar la actualización del componente (WPBakery). Mi caso es diferente, yo ya tengo instalado un wordpress 5.0.2 y la plantilla Fatmoon (Demo-Charlotte) por lo tanto para dicha versión es obligatoriamente tener actualizado WPBakery para que funcione correctamente, voy a comenzar con el diseño desde hoy. Gracias
Seeing that your name is Daniel, I thought you spoke in Spanish, it is more difficult for me to speak in English. For the next conversations I write in English
Thanks, Air. Actually I was asking about WPBakery 5.6. Already updated to FatMoon 2.3.1, but it doesn't look like the latest WPBakery was included with it. When will we get the updated WPBakery 5.6?
It doesn't seem to work. I've updated to Fatmoon 2.3.1, but the plugins page says that we need you to push the plugin. I also went through the Fatmoon 2.3.1 ZIP file and couldn't locate the WPBakery plugin. Can you provide the folder path where it's located in the ZIP file?
Solved it. Updating to Fatmoon 2.3.1 doesn't seem to update the WPBakery plugin. I found the updated plugin zip within the Fatmoon update (fatmoon/advance/plugins/js_composer.zip) and performed a manual update of the plugin. It's now all set.
speterkane said: Updating to Fatmoon 2.3.1 doesn't seem to update the WPBakery plugin.
Ofcourse not :-) I have gave you link yesterday that gives precise instructions how to update bundled plugin after theme update. Theme can not decide for you to update plugins on theme update, as this is not desired.
Hi there, i have the same problem as speterkane. WPBakery still stucks in 5.5.2 - all efforts to update ended in a "you need a registration" error. In earlier updates of Fat Moon, everything works like a charme. Not this time.
My solution was simply to deactive the plug-in, then I was able to update it.
I´m also wondering if Fat Moon 5.3.1 is compatible to WP 5, now. Could you clearify this?
nilsschirmer said: WPBakery still stucks in 5.5.2 - all efforts to update ended in a "you need a registration" error. In earlier updates of Fat Moon, everything works like a charme. Not this time.
WPBakery has story of breaking option of updating plugin when it is bundled in theme. It is not the first time our customers have problem with updating this plugin from theme. That is why we described it in documentation(read below).
nilsschirmer said: My solution was simply to deactive the plug-in, then I was able to update it.
Hello, a new version of WPBakery Page Builder v5.7 has been released for the version of wordpress 5.1.1 .. How can we update this new version of WPBakery Page Builder?
WPBakery Page Builder Tienes la versión 5.6. Actualiza a la 5.7. Ver detalles de la versión 5.7. Compatibilidad con WordPress 5.0.4: Desconocida Compatibilidad con WordPress 5.1.1: Desconocida
13.02.2019 - ver 5.7 - Update: Compatibility with PHP 7.3 - Fix: WooCommerce corrected editable role - Fix: Page preview styles independent from view page
I will not be able to release an update before January, as I am in the middle of work on version 2.3.0
I would also recommend waiting with the update to WordPress 5.0 as we have explained in our article https://apollo13themes.com/dont-update-to-wordpress-5-0/
If you are in a real rush I can send you zip file with WPBakery on Monday.
No, i have strated a new website with WP 4.9, i will wait for 2.3 to update WP to 5.x
Thank you and good luck
Best Regards
Please write it again in English
Best Regards
I am sending you a link to new WPBakery by private message in a few minutes.
You can then install it manually, but first, you will have to deactivate and delete the old version of WPBakery plugin.
Thanks!!
Yes, FatMoon update 2.3.1 was released on 8th January. Please update:-)
WPBakery 5.6 is in FatMoon 2.3.1.
Please follow https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-bundle-plugins/
This page (https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-bundle-plugins/) may need to be updated for plugins that need a license like WPBakery.
https://rifetheme.com/apollo13-framework/docs/plugins-recommendations/wpbakery-page-builder/
Glad you made it:-)
Great! Exactly as described in documentation https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-bundle-plugins/update-bundled-plugins-issues/
Yes, it was compatible with WordPress 5 before it was released.
O man, somehow I have missed it in the latest udpdate. We will release another update in Monday and add this verison.
Thanks for the info!
