Hi everyone, I'm struggling with a website I just made.
They asked me to put some password protected pages and everytime I try to create one the page comes out empty with just the password box in it, no title, no header, locker icon, nothing.
And there's more, every time I activate the password protected option on the page and then click on "publish" and try to edit the page with Elementor it says I need to call "the_content" function in the template of that page.
I tried deactivating the plugins, reinstalling the theme, reinstalling Elementor and other stuff but nothing worked.
Thanks for any help!
If the page has set a password it doesn't call
the_contentfunction that is importatnt for Elementor.However, if you visit your passworded page, enter a password, and you will see proper content after form submit, you will be able to edit it in Elementor.
Another solution is to disable password for editing time and add a password after you finish your page.
Could you show me a link so I could see how it looks?
I'm sorry for the late reply but I've been on holiday and then I totally forgot about it.
I have no idea why the other elements of the protected page template doesn't appears but here's a link for you to have a look at:
https://www.paoloilfotografo.it/album/protetto/
If you have any solution in mind please let me know.
Cheers,
Enrico
Maybe you have set page for password protected page. Please try to set it back to default look in ppearance → Customize → Page Settings → Password protected page template.
Thanks for helping with this stupid issue
One more thing, now how can I customize the text in the "submit" button?
Cheers
You can edit it in photoproof\advance\utilities\password.php line ~13
You can also do it in theme translation as you said :-)
Cheers
