Hi Air
I'm back onto working on the
https://zauberduo.flyart.com/ site using your "shield". I know I can do some stuff with the height but can I modifiy the width as well?
And even more important: can I alter the shape (I will need an "egg" shape rather than a shield...
Thanks in advance
Pascal
Already found out about tweaking the width myself.. sorry for bothering... but (so you are not bored
Thanks, Pascal
I believe that everything is possible, but none of these things are available from theme options.
Changing shield shape - this would require an overriding whole file of theme template in child theme - fatmoon\header-variants\horizontal-one-line.php - SVG of the shield is defined in lines 64-74. You could do it with custom CSS. Please post a live link to the website where you want this to happen, and link to file on the same server that you want to replace the logo with on hover.
Thanks for the infos.. I might have found a workaround that (hopefully) would not require modifications.. but I have to present it to my client before I know
Thanks, Pascal
