I would like to know how I can change the blue line which appears around the submenu icon when clicking the item. Can't find where I can change it! I would like to make it transparent.
And right away also another question: When scrolling the homepage the different menu-items disappear (e.g. When I click blog, the page scrolls to the blog section, but the other menu-items are not seen in the header menu anymore). How can I avoid that they disappear?
Sterhes said: I would like to know how I can change the blue line which appears around the submenu icon when clicking the item.
The thing that you see is focus ring, that is a way that browser marks selected interactive elements. It is very important for disabled users or users who use the keyboard to navigate on websites.
So about your topic - please change color in Customizing → Header settings → Sticky header - Override normal settings → Main Menu : Links : Text color.
To change selected item color check, in the same panel, option Main Menu : Links : Text color - on hover/active.
You can disable it as described here https://rifetheme.com/help/docs/customizing-the-theme/header/main-menu/#accessibility-focus-rings-on-the-menu
Please post link to live site so I could check what happens.
