Hi Air
For a site using Rife Pro in need to set up a wooCommerce shop. But it looks like the theme settings take over woo Commerce?
As I need a specific design I want to make the shop pages using Elementor templates for Woo Commerce ... how can I "deactivate" the Rife settings?
Thanks, Pascal
What do you mean by the theme settings - could you give some examples of what is happening and what you expect to happen?
Not exactly sure what I mean
Thanks, Pascal
1. Go to theme files and rename rife/woocommerce to rife/_woocommerce. Next check is it better for you.
2. If this will not be enough, try going to rife\advance\utilities\woocommerce.php and remove contents of this file.
If this will result in breaking your site totally, then revert this change.
Last way to remove theme things would be to clean WooCommerce styles from the theme:
Go to rife\css\woocommerce.css and remove contents of this file.
This should be enough unless something is coming from our plugin, but I will need a live link to verify such things if you encounter any.
Thanks a lot.. great news: the simplest solution (No. 1) did the trick!
Once more.. fantastic support and great work!
Cheers, Pascal
