I wish to hide the thin vertical line at the right in post and pages (and all). Its like
http://support.apollo13.eu/discussion/568/how-to-remove-the-light-gray-outline-between-navigational-bar-backgrounds#Item_13 but the vertical, thanks
Other thing I wish to know is how to hide the titles in a category page
to hide it you can use this custom CSS With regards.
body.category, .info-bar, .page-title{
display: none; !important;
there cause it means to hide whole category page and also hide every title of page.Use of
!important
is also incorrect.With regards.
body.category .info-bar .page-title{
display: none;
body.page .info-bar .page-title{
display: none;
I want to hide all the titles that appears in pages, blog post, categories, archives by category, archive by tag, etc... See attached images, I've bookmarked the title in blue
http://www.miguelangellopezgalan.com/tag/atocha/
sorry and apologize for the inconvenience.
If on some pages it won't work send me links to it and I will improve this custom CSS.
Yes, it worked. but now you'd know how to reduce the space between the header and the content and make always the same space. see attached, I´ve bookmarked the space with a red rectangle.
Thank you.
