hide thin line in post or pages, and hide titles of category
edited December 2012 in Hypershot Posts: 26
I wish to hide the thin vertical line at the right in post and pages (and all). Its like http://support.apollo13.eu/discussion/568/how-to-remove-the-light-gray-outline-between-navigational-bar-backgrounds#Item_13 but the vertical, thanks
Other thing I wish to know is how to hide the titles in a category page
    For shadows use this custom CSS
    body.page article, body.single article, body.page article, body.single article{
    box-shadow: none;
    About titles: you want to hide title of category, or all titles. Screen shot with shown exactly what you wish to remove might help:-)
  • Yes all titles (in blue)
    1920 x 1200 - 389K
    1920 x 1200 - 253K
    to hide it you can use this custom CSS
    body.category .info-bar .page-title{
    display: none;
  • in pc custom css plugin it woks this way:
    body.category, .info-bar, .page-title{
    display: none; !important;
    edited December 2012 Posts: 10,970
    You shouldn't add comma, there cause it means to hide whole category page and also hide every title of page.
    Use of !important is also incorrect.
  • And This?
    display: none;
    body.page .info-bar .page-title{
    display: none;
    I don't quite get what you want now:-) I give you answer, just add it at end of Custom CSS field and you are done. Or you are now asking indirectly about hidding some other titles?:-)
  • Yes, sorry maybe it´s my english, i can´t explain as good as i want.
    I want to hide all the titles that appears in pages, blog post, categories, archives by category, archive by tag, etc... See attached images, I've bookmarked the title in blue
    http://www.miguelangellopezgalan.com/tag/atocha/
    sorry and apologize for the inconvenience.
    1920 x 1200 - 887K
    1920 x 1200 - 915K
    OK :-) I thought you mean only in categories :-)
    display: none;
    This should work:-)
    If on some pages it won't work send me links to it and I will improve this custom CSS.
  • Hi Air,
    Yes, it worked. but now you'd know how to reduce the space between the header and the content and make always the same space. see attached, I´ve bookmarked the space with a red rectangle.
    Thank you.
    1920 x 1200 - 776K
    1920 x 1200 - 190K
    1920 x 1200 - 880K
    1920 x 1200 - 786K
    Try this custom CSS
    .info-bar .inside{
    display: none;
    and if it is too much space reduction, use this
    .info-bar .inside{
    padding-top: 0;
