I have the problem that when I use the fit landscape option instead of "fit always" my images gets cut off both at the top and bottom which means I have to add extra spacing to my images - that doesn't look too good. Is there a solution to this or a optimal image resolution you guys can recommend? I would like to have my images in fullscreen mode as it looks so much better.
I understand what you need. There is no easy bulletproof way to do it as we didn't plan that users would love such image placement better then ours. Now we are wiser :-)
thank you so much for the quick response. I tried out the CSS settings. The image budged a bit but not much. I tried to alter the values however that did not change anything. Maybe I am doing something wrong. I added the code into the stylesheet.css. If you have the time you can have a look? or else I will just have to wait for an update.
BUT you don't have to do it. I think you should add this CSS from post via plugin like this http://wordpress.org/extend/plugins/pc-custom-css/ activate it, and next go to Appearance->Custom CSS. There you can insert your custom CSS.
Anyway our other theme suffers from same issue and this is what we came to:
http://support.apollo13.eu/discussion/comment/2256#Comment_2256
It should also work for spaceship. You can however experiment with those CSS values.
thanks!
style.cssbut didn't set theme to uncompressed mode http://apollo13.eu/docs/spaceship/#!/advance_menu_use_compressed_js_amp_css ;-)BUT you don't have to do it. I think you should add this CSS from post via plugin like this http://wordpress.org/extend/plugins/pc-custom-css/ activate it, and next go to Appearance->Custom CSS. There you can insert your custom CSS.
Then it should make difference.
Have a good one!
Duc
