For some reason my menu is appearing at the bottom of my header rather than in the middle of it - how do i add more white space between the menu and the bottom of the header ? Also when i hover over the words in the menu, an icon appears above the word, but it looks all out of alignment. what's happened?
https://snipboard.io/ZrNchL.jpg www.wordalchemists.co.uk
It seems there are some HTML errors introduced or CSS errors. Not sure what exactly happens.
It seems you don't use the logo in your header right? Maybe try to switch to another header variant in Appearance → Customize → Header Settings → Type, variant, background → Variant.
Check if this will help at all.
There is also a chance that some plugin is introducing errors into the page and that is why the layout is affected.
Anyway. Can u help me fix the issue I described please. This is the only variant I want, I just need to make the menu text I the header middle aligned like it's supposed to be, so it is in line with the bookmark and social icons
