$_title = sprintf( esc_html__( 'Category Archives: %s', 'fatmoon' ), '<span>' . single_cat_title( '', false ) . '</span>' );
$_title = sprintf( esc_html__( '%s', 'fatmoon' ), '<span>' . single_cat_title( '', false ) . '</span>' );
traveljess said: *Would you like me to create a new thread for this question?
traveljess said: Is there an easy way to add a different featured image to each category page too?
.category-beauty.posts-list .title-bar.outside { background-image: url(http://192.168.1/4/2018/11/pine-small.jpg); }
category-beauty
<body>
You can do it by editing file in rife/index.php line ~49: change it to: If you want your change to be safe, please use a child theme for Rife Pro, and copy this changed file there.
https://rifetheme.com/help/docs/installation-updating/installing-the-rife-child-theme/
Is there an easy way to add a different featured image to each category page too? *Would you like me to create a new thread for this question?
Do you mean the image that appears behind title bar?
Best would be to use custom CSS with a class for a specific category Replace part
category-beauty
. You can find this class name in<body>
element.With kind regards.
