Hi.
I am going to publish my web that I have recently finished and I want to ask you a question.
I want to change the word "work" in portfolio section :
https://imagingfactory.thednscluster.com/work/ (General)
https://imagingfactory.thednscluster.com/work/books/ (Individual works)
I would like to change both to another :
https://imagingfactory.thednscluster.com/publicidad/https://imagingfactory.thednscluster.com/publicidad/books/to another one in spanish for better understanding.
How I could change this word?
Regards.
As for the slug "work" you can change it in https://rifetheme.com/apollo13-framework/docs/customizing-the-theme/works-portfolio-settings/single-work-slug/
As it is explained there, you should name your works list page slug, something different then what will be your slug for works.
In other words, it is not safe(because of WordPress architecture) to name slugs: You have to make those slug different like it is originally: wor With kind regards.
Ok, I would like to confirm what you are telling to me to ensure that I have understand it.
I can't use the same slug to the portafolio section and the slug name for its works.
So if want to change www.com/portfolio/ as the URLs comes by default and also I want to change the slug name for the portfolio works, the slug for the works have to be different than the slug section of the portfolio.
In this moment, I could not change the slug "work" for "portfolio", is it?
So the correct configuration to the change portfolio general slug and the slug of its entries, should be for example this:
www.com/publicidad/ - (General) => Changing the slug name from the page
www.com/trabajos/books/ - (Individual works) => Changing the slug from the Customization panel
Is it correct?
Regards.
You can just be sure you don't have such a page/post with the same slug anywhere else, also it is not in the trash.
It looks correct :-)
