I love the theme. Works awesome in Chrome and Firefox. And even on mobile in Safari. HOWEVER, I am having an issue with Safari on my desktop. I am running version 12.0 - which I am aware is not the most current. But is not that far behind. The issue is this: ReferenceError: Can't find variable: IntersectionObserver. From some google searching I have found this might have something to do with Elementor and safari, but I am not seeing the issue on any of my other Elementor designed sites (I have done 3 or 4 with the builder so far). Do you guys have a work around for this? Note -- I have upgraded to Elementor Pro. Happy to send whatever credentials you need to access the site - just let me know. THANKS!!
Could you share a link to your website where the issue happens?
Also if you could share a link to your google findings it would as well help.
Funny thing is ... I have another license of this theme. Using it for another client with a different hosting provider -- and I am not having any viewing issues in safari on my desktop -- but on the ipads the text is all missing -- just like the first site.
I am going to give you both site links. https://newirth.tv/ and http://staging.prewittandco.com/ (this is the one that works okay in safari desktop)
Could you please take a look. I love the theme but I really need it to work across all platforms. As I am sure you can understand.
I have just checked your website on desktop Firefox and on Safari on iPad, and I can not find what is missing in the Safari version.
Could you mark on a screenshot what is not displaying, becasue I feel like searching for the needle in the hay stack ;-)
The other site staging.prewittandco.com looks fine on desktop in all browsers.
As for your issues that you have described - I can also see them on my old iPad. Strange that they are not visible on Chrome, when the browser is narrowed.
As far as I know Safari has few strange issues with rendering layouts.
In the past, we ran into some issues in Safari when we have used moving background images that were stretched. It gave very weird glitches.
We had to switch to more static backgrounds, to solve issues in Safari. Our demos suffered on this, but at least it worked everywhere :-)
I suspect that there is something that you have set when setting up the layout in the Elementor that triggers these issues.
On your place, I would copy this page, and make some experiments on this copy until you will find out which setting gives these glitches.
For example: remove all sections besides one that has white margins. Check on Safari if margins are still there. If they are, play with settings of the section, or try to recreate it from scratch and check on each step on Safari the final result.
Unfortunately, it can be a painful and time-consuming process to find out the source of each issue.
Damn you "Safari glitches" :-)
