Photoproof and iPad 7 broken
edited October 7 in PhotoProof Posts: 74
Any idea why is site broken on iPad 7 on landscape? When is normal position site is ok
Post edited by robi052 on
    I don't have iPad 7 to test, but I believe it has bigger reported resolution width then older iPads and in horizontal mode it goes into desktop browser breakpoints.
    You can achieve similar effect on a desktop browser by narrowing the window.
    I can help you either by narrowing your logo for certain resolution widths or by making menu font smaller. What do you think?
    Thanks. I try put smaller fonts
    edited October 14 Posts: 10,488
    Hey Robert :-)
    Please try such custom CSS:
    @media only screen and (max-width: 1080px) {
    	.top-menu > li > a, .top-menu > li > span.title, .top-menu .mega-menu > ul > li > span.title, .top-menu .mega-menu > ul > li > a {
    		font-size:      16px;
    CSS code Donat help. Whet i Set ni Safari font size to 85% then is ok, but when is 100% problem is here.
    2160 x 1620 - 916K
    2160 x 1620 - 899K
    Where exactly have you added this CSS, as I can not find it on your website?
    Delete after try. I add again ni Customize=> Custom CSS
    Try now
    I have just checked and it works fine. You have to clear cache in your browser, as it seems your page currently is heavily cached.
    You can always try to reduce font size even further.
    Now is ok. Thanks 😃
    2160 x 1620 - 4M
