How remove pagePP-3.jpg from post-8238.css? Same error 404 like before
Site
https://www.robertobilic.com/CSS
https://www.robertobilic.com/wp-content/uploads/elementor/css/post-8328.cssThanks
UPDATE
#18328 is contact page
https://www.robertobilic.com/kontakt ... In this page missing ¸¸How can I help you¸¸. It is covered with menu at top
UPDATE
#2 Found and missing contact5-3.jpg file in same refferer/css file
Found missing file PPBG1-3.jpg post-8830.css
Sorry for not getting to you earlier.
Glad you have solved this easily.
Problem is not resolved.
Problem page
Problem CSS
Missing files
2018/06/contact5-3.jpg
2018/06/pagePP-3.jpg
I try edit contact page with elementor, but cannot found where is this images.
And try in Customize but cannot found that.
First problem https://support.apollo13.eu/discussion/6197/missing-png-files#latest
is resolved and now is ok. But cannot find in Chrome Inspector where is this missing files in contact page. Only in CSS. In Inspector Network and Console tab see this missing files, but in Elements tab cannot find where is this files in page.
2018/06/contact5-3.jpg Is set as a background for first main section with "KAKO VAM MOGU POMOĆI?" It seems to be the most outer section.
2018/06/pagePP-3.jpg Is set as a background for the third main section with "Work with Me!" It seems to be the most outer section.
Use Elementor navigator to get to it https://docs.elementor.com/article/378-navigator
contact5-3.jpg found and remove. pagePP-3.jpg cannot found, but create example jpg file with this name and then fond. How is all fine.
Thanks again
