I have an album assigned to my homepage and only one photo is appearing, even though I've uploaded 8 photos. When I switch the albums, I notice the same thing, it's only showing the first photo and none of the others. I'm not sure if this an issue with an update or a bug, but if anyone could help, that would be great!
The theme & plugins have been updated. I downloaded the plugin above but nothing changed. I have not made any code modifications. Is there something I need to do?
I have updated the theme and everything works great. I suspect there was some unintentional code change that caused this, however, it was hard to spot.
Could you share a live link to the page where it happens?
Want to thank me with coffee?
Yes, here's the live link https://pwillisjr.com/
Kind regards
It looks like some tags are not closed, and the scroller collapses in it-self.
1. Have you made any code modifications?
2. Could you update the theme and companion plugins? → https://rifetheme.com/apollo13-framework/docs/installation-updating/updating-theme/manual-theme-update/
Really appreciate your help!
Kind regards
