Updated via ftp and regular upload, deleted the old theme before any update ...
Warning: array_merge() [function.array-merge]: Argument
#1 is not an array in /var/www/mysite.com/public_html/wp-content/themes/hypershot/advance/meta.php on line 287
Warning: Invalid argument supplied for foreach() in /var/www/mysite.com/public_html/wp-content/themes/hypershot/advance/meta.php on line 287
Warning: Cannot modify header information - headers already sent by (output started at /var/www/mysite.com/public_html/wp-content/themes/hypershot/advance/meta.php:287) in /var/www/mysite.com/public_html/wp-includes/pluggable.php on line 876
That must be some setting of server or other issue.
Could you please try using template with this patch that is in zip?
Just copy this file to
hypershot/advance
of new version.Thanks for reporting and for further help.
Thanks.
For some odd reason I did some delete before posting patch. This should be OK.
Thanks again!
Thanks.
I just purchased the theme.
Before I get started.
Should I install WP 3.5 before installing the theme?
Or should I use the older latest WP version and update the theme when it is is released on Themeforest?
I saw the update to Version 1.0.3 Updated: 14.12.2012 which says it is good for WP 3.5 but in the Themeforest comments there is a comment from only 2 days ago that is linked to this page that says "Solution is in newest update that still waits for acceptance on ThemeForest".
Thank you.
Yes you can install Wordpress 3.5 :-) As far as I have tested it works fine with WP 3.5
