Discussions
Categories
Home
FatMoon
Elementor convert?
R3ll
June 2021
in
FatMoon
Hi, i've just purchased the FatMoon theme and imported the Zaria design wich i found it very nice btw but my question is: is there a Elementor version of this theme? or is there a way to convert it from the wp bakery plugin? Thank you
Air
June 2021
FatMoon was made with WpBakery, and there is no easy way to convert it to Elementor. It has to be done manually.
Not an easy or fast task.
Just to be clear FatMoon is compatible with Elementor, however, pages were prepared in WPBakery.
R3ll
June 2021
Thanx for your answer, another question please: i can't find to replace the favicon, can't find the site identity in customizer and no similar option
Air
June 2021
If you don't see it in the customizer, there is a chance that some plugin have switched it off or hidden it.
Try disabling all plugins except for
Apollo13 Framework Extensions
, and then check again.
R3ll
June 2021
As it seems you forgot to add this option in the theme customizer
, all these options comes with the theme
Air
June 2021
It is there, we didn't mess with any option in a while(years). Try reinstalling the theme if you still do not see it.
If it will not help, I will take a look at your installation.
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
117
OneLander
333
PhotoProof
617
Rife
40
Agency
130
Starter
887
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
June 2021
R3ll
June 2021
Air
Discussions
Categories
Sign In
Try disabling all plugins except for Apollo13 Framework Extensions, and then check again.
