Discussions
Categories
Home
Rife
wpbakery update
contentologue
October 2021
in
Rife
Since a moment now, I can't update wpbakery, it asks for a license and it's bugging and won't work anymore...
Thank you for your help,
Sophie
contentologue
October 2021
Hello ?
Air
October 2021
Hey Sophie :-)
I see you wrote again while I was checking your topic :-)
If WpBakery blocks updating it to the newest version bundled in the theme, please deactivate it, and then follow the normal update procedure.
1. Deactivate WpBakery plugin.
2. Go to Appearance → Install Plugins
3. Update WpBakery from there.
Hope that helps.
contentologue
October 2021
Hi !
Thank you for your answer.
When I deactivate wpbakery, I go to Plugins (nothing in Appearance) -> Install plugins and all I see is Elementor, not wpbackery. So I reactivated it, and then I go to Install plugin, I update and it says it needs a license.
Air
October 2021
OK, I see.
So in this case, you will have to do a manual update of the plugin.
Go to this link
http://apollo13.eu/temp/wpbakery.zip
and download the plugin.
Next go to your admin panel → Plugins → Add new → Upload plugin → add plugin that you have downloaded from the above link.
Before doing this, deactivate wpBakery just in case it would block updating again.
378 x 187
6K
contentologue
October 2021
I worked perfectly. Thanks a lot !
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
114
OneLander
324
PhotoProof
589
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
October 2021
Air
October 2021
contentologue
Discussions
Categories
Sign In
Hope that helps.
Go to this link http://apollo13.eu/temp/wpbakery.zip and download the plugin.
