i like to get my portfolio album:
https://lichtwerk.haus/portfolio/working as shown here:
https://rifetheme.com/photoproof-8/album/with-filter/- Every tile should be a same sized square.
- And the category should be shown.
i am looking forward for your replies.
Regard Carsten
Please go to Appearance → Customize → Albums Settings → Albums list → Choose the proportions of the bricks → 16:9
As for categories in the same settings Enable Appearance → Customize → Albums Settings → Albums list → Album meta: Categories
Hope that helps.
Do i have to chabge the settings in every album too.
Why shouk i set 16:9 when i like to get squares 1:1?
Kind regards Carsten
2. However, now that I look, it seems like your images aren't resized at all. It could be some issue with the server configuration. Could you check if directory
wp-content\uploads\apollo13_images
was created and does it have any image inside? 3. Please check again if your album has any category selected.4. Do you have any cache plugins installed and activated?
Yes, you shouldn't set the same slug as custom post type(album) slug https://rifetheme.com/help/docs/customizing-the-theme/albums-settings/single-album-slug/
As for 2, I don't have any idea right now.
PS. Please reply on the forum, as otherwise your replies might get lost.
I have logged into your website and all albums loaded in squares, as you wanted.
Do you see this as well?
As for categories, your albums currently don't have them set. You can try adding categories by Quick edit.
Go to firefox, and run your website in the "private mode". Check if it is displayed correctly.
If it is , then log into your account, still in the private mode, and check is it still displayed correctly.
Let me know how it went.
PS. Please reply on the forum, as otherwise, your replies get to the e-mail account that is not monitored and filled with spam ;-)
