Issue with rife included "slider revolution"
in Rife Posts: 304
Hi Air
It's been a while but I been having this issue for some time now and it didn't get fixed in the meantime. After updating the "Rife Theme" the included slider revolution plugin aks for being updated but it deosn't work (on multiple site) You can see the error in the attachend screenshot
Thanks Pascal
    Updates for this plugin are released with the theme updates. So you will not be able to update it from the screen that you have shown on your screenshot. Unless you will get an individual license for this plugin.
    I will release an update for the theme in few weeks, as soon as I will get my workstation fixed.
    Hey Air
    I know! The Update request came from updating your theme but upon trying to actually update the plug in the error message shows...
    Sincerely
    Pascal
    What version of the plugin do you have currently?
    I suspect that this plugin is sending you its own update notices, as I have just checked and it updates without problem to the version that is bundled with the theme.
    That might be possible although it's strange as it says the theme wants an update of the plugin? Here's what I have: Rife Version: 2.4.16 and Slider Revolution Version 6.5.19
    Thanks, Pascal
    OK. You should be able to update to 6.6.11 version.
    If Plugin is failing to update, please make a manual update as explained here either by uploading by FTP or manually uploading the plugin via WordPress
    Please check the private message for a link.
    Hi Air
    Thanks for the download link, that solves the issue!
    Have a great day
    Pascal
    Hello
    I am still having this issue. every site I use rife with does not update revolution slider with the notice "package not available" .. last time you just sent me the plugin to upload but this is of course not a practicable solution for all sites over time...
    Thank you
    Pascal
    Hi, I will take a closer look to this issue.
    Support, The
    Great, thank you
    Hello again
    It's been a while but I still have the issue that some of my sites using rife pro still don't update revolution slider - again the same message.. this time for this site: https://metropolkurier.com/
    and the same happens to https://baselathome.ch/
    and to many more I'm trying to update at the moment. I hope you can find a solution, thank you
  • Yeah... problem seems to be deeper than it seemed to be. Revolution Slider changed the licensing and we cannon include the package in the theme anymore.
    Support, The
    That's not good! What is you plan.. one of the reason I liked that theme is the iclusion of revolution slider...
  • Well, this is completely their decision.
    They moved away from the Envato marketplace CodeCanyon (as we did)
    They removed the lifetime license.
    So - it looks like market's shifts are something we need to live with.
    Support, The
