I need assistance with the website navigation menu styling.
Currently, the black background highlight appears not only on the active/current page (which is the desired behavior), but also whenever a menu item has a submenu or when the menu item is in its idle/default state.
What I want instead:
The black background highlight should appear ONLY for the currently selected/active page (for example, HOME when I am on the homepage).
Menu items that are not active should remain transparent/default in their idle state.
Simply having a submenu should NOT trigger the black background.
Hover behavior can remain separate if needed, but the persistent black background must be reserved only for the active menu item.
In short:
Active page = black background
Inactive menu items (including those with submenus) = no black background unless intentionally hovered
Please let me know how this can be adjusted.
Thank you.
PS, the domain is www.tokyoia.com
You can add an extra class 'force-transparent-menu-item' to this very menu item (the top one) and use this css definition in Appearance>>Additional CSS
What I want is something similar to this (attached), the black box should only appear on the page you are reading.
PS. Please understand that I am in no way criticizing everyone's work here, I just use this as a tool to help find a solution for the both of us fast
/* Strict version: turns off as soon as mouse leaves the parent item */
body.home #menu-item-15216:not(:hover),
body.home #menu-item-15216:not(:hover) > span.title {
background: transparent !important;
background-color: transparent !important;
background-image: none !important;
border: none !important;
border-image: none !important;
outline: none !important;
box-shadow: none !important;
body.home #menu-item-15216:not(:hover)::before,
body.home #menu-item-15216:not(:hover)::after,
body.home #menu-item-15216:not(:hover) *::before,
body.home #menu-item-15216:not(:hover) *::after {
content: none !important;
display: none !important;
visibility: hidden !important;
opacity: 0 !important;
border-color: transparent !important;
If it works for you - that's ok.
Would be cool to have wide fix, but it is what it is. Have a great day.
