Menu hover/submenu styling issue – black background should only appear for active/current page
GBGGBG
in Rife Posts: 9
I need assistance with the website navigation menu styling.
Currently, the black background highlight appears not only on the active/current page (which is the desired behavior), but also whenever a menu item has a submenu or when the menu item is in its idle/default state.
What I want instead:
The black background highlight should appear ONLY for the currently selected/active page (for example, HOME when I am on the homepage).
Menu items that are not active should remain transparent/default in their idle state.
Simply having a submenu should NOT trigger the black background.
Hover behavior can remain separate if needed, but the persistent black background must be reserved only for the active menu item.
In short:
Active page = black background
Inactive menu items (including those with submenus) = no black background unless intentionally hovered
Please let me know how this can be adjusted.
Thank you.
PS, the domain is www.tokyoia.com
    These two elements are recognized by the WordPress as 'current-items', so this is somewhat default behaviour of 'make the Menu parent item of the active subitem' more visible.
    You can add an extra class 'force-transparent-menu-item' to this very menu item (the top one) and use this css definition in Appearance>>Additional CSS
    .force-transparent-menu-item {
        background-color: transparent !important;
    946 x 742 - 1M
    Support, The
  • GBGGBG
    No effects (see attached file).
    What I want is something similar to this (attached), the black box should only appear on the page you are reading.
    967 x 253 - 469K
    1579 x 590 - 1007K
  • GBGGBG
    edited May 12 Posts: 9
    OK, this fixed it. I asked ChatGPT for the rescue. But since you guys are the developers and that you know better how your theme works, please have a look and tell me if this solution is a fix worth keeping and that will not create more problems elsewhere.
    PS. Please understand that I am in no way criticizing everyone's work here, I just use this as a tool to help find a solution for the both of us fast :smile:
    /* Strict version: turns off as soon as mouse leaves the parent item */
    body.home #menu-item-15216:not(:hover),
    body.home #menu-item-15216:not(:hover) > span.title {
    background: transparent !important;
    background-image: none !important;
    border: none !important;
    border-image: none !important;
    outline: none !important;
    box-shadow: none !important;
    body.home #menu-item-15216:not(:hover)::before,
    body.home #menu-item-15216:not(:hover)::after,
    body.home #menu-item-15216:not(:hover) *::before,
    body.home #menu-item-15216:not(:hover) *::after {
    content: none !important;
    display: none !important;
    visibility: hidden !important;
    opacity: 0 !important;
    border-color: transparent !important;
    Post edited by GBG on
  • GBGGBG
    No?
    this css code is a solution for you only since '#menu-item-15216' points to the menu item with specific ID. It means that this will work for your website only.
    If it works for you - that's ok.
    Support, The
  • GBGGBG
    edited May 22 Posts: 9
    Indeed, and if you are ok with that, then GREAT! Thanks!
    Would be cool to have wide fix, but it is what it is. Have a great day.
