Hey again, Having an issue with the album background on the front page. The album background doesn't load on the front page. I can see the 'loading' image, but the background images won't load. If I set the same album on a page, it works. I searched the forum and I read that another theme had the same problem. I think it was a plugin for that theme, so I deactivated all my plugins, but the album background still won't load. Any tips?
Regards
(Btw, Air, if you need to access my WP, the username and password still work)
I wanted to investigate right away, but now I don't know what exactly is not working as you have probably changed your front page :-) So, is it: 1. Background album/image under blog page set as front page? 2. Full width album(slider) set as front page? 3. Bricks Album set as front page? 4. Static Page with Background album/image? 5. Something else?
I'm sorry for bothering you! I just figured it out.. I now used the Front Page and Blog method (as described in the documentation) and just set the background album at the 'Blog' page. I couldn't do this before, because I hadn't set up the front page properly. So sorry for wasting your time!
I have a new problem though.. The background album on the front page only has one image, despite the fact that there are more images in the album. I also have autoplay on in the album settings. The image also won't change if I press the 'next button'. Just compare the 'Test' page with the front page. It's the same album..
So, is it:
5. Something else?
Regards
Sorry!
