Earlier today my host/hostgator released a Word Press 3.5 update automatically after which my home page is blank. I have a logo and I can see the menu. However my slider album I had as my home page does not come up. I go back into the hypershot theme and the settings appear to be fine. I called hostgator and they are going to restore the site back to the original format before the 3.5 update. In the meantime, I want to know how to fix this. Can you please take a look at my web site www.virimages.com
We had similar issue in our previous theme and maybe same goes for Hypershot http://support.apollo13.eu/discussion/comment/2526#Comment_2526
Mainly it is about SEO plugin + WP 3.5 making some mess with our theme. I will check it later, and if it the same I will try to make some patch till Monday. But please confirm if you use same plugin as described in topic.
Our website is www.virimages.com
And here is a screen shot of issue:
I had a similar thing happen, I changed the font size for the main menu and it all changed back to how it was before the update.
Sorry for inconvenience.
