Do you really need this /new in Site Address (URL)?
IF not please delete it and try then. If it won't help or you need this /new in your address then you will have to send me temporary access to your WP and FTP so I could check there what is going on? Send it here on forum via private message.
I see you your contact page is
http://bernardbertrand.com/new/contact/
but after sanding you land in
http://bernardbertrand.com/new/new/contact/
This subfolder is problem. Please post screen shot of settings in
Settings-> GeneralWith regards.
/newin Site Address (URL)?IF not please delete it and try then. If it won't help or you need this
/newin your address then you will have to send me temporary access to your WP and FTP so I could check there what is going on? Send it here on forum viaprivate message.
I ll drop you a pv message
thanks
by changing in
advance/utilities.phpin line 308this to this I will try to find better way to do it and add it in next update.
