It is not styled for such small screens as it takes too much place(crowd, like in your other post) and also it is "brutally" overwritten so enabling it would require messing in main style.css file(first deactivate compression http://apollo13.eu/docs/hypershot/#!/advance_menu_use_compressed_js_amp_css) remove this lines from line ~3830:
proinsus said: Is it possible to have an Album item that shows only on mobiles?
It is not possible. Firstly you would have to know how to detect properly what is "mobile" and there is no way for this. In our theme we response on current device screen size and does it have touch gestures enabled to prepare layout for it.
proinsus said: Could we have a button that could display the text? It is very important to have the info of the work.
I thought about it many times as I am also not convinced that there is no album info on smallest screens, but I just have no idea how to make it efficiently so it won't become pain in ass for anyone. Maybe we should hide this slide numbers by default and use this space for photo info. I will think about it.
style.cssfile(first deactivate compression http://apollo13.eu/docs/hypershot/#!/advance_menu_use_compressed_js_amp_css)remove this lines from line ~3830: Still enabling this can be buggy.
Gonzalo
Thanks for pushing me into finding solution ;-)
