No, no :-) I don't know if we are, I was just curious if you have test it with Hypershot, cause this is one of things on my TODO list, so thanks for sending this link. I will try to test this plugin with our theme soon.
Could you post screen shots or live link of this issues, what is happening? I don't tell that I will fix it right away, but this could be issue with our architecture what would be pretty nasty.
In another post I was asking how to insert a Shorcode into home, but they are not accepted. Even that there is a content area whe you select Album list,
ooo man ... "short cut" sounds nothing like "shortcode" when you read it.
You will have to get some deeper understanding of wordpress to get that this page that you choose for front page is almost for nothing when you don't use static page as front page(what I explained in mentioned topic). Switch to PageHypershot theme-> Main settings-> What to show on front page? and your shortcode will work.
From you answer I understand you are. Great. I was just letting you know, since I couldn't find the theme name in their list.
Cheers
Gonzalo
www.proinsus.com
G
Hypershot theme-> Main settings-> What to show on front page?and your shortcode will work.With regards.
