Hello there.
First of all, thank you for a very nice theme. Almost everything works as advertised but I have run into a display problem when viewing the theme on the Chrome browser. When browsing through an album and the aspect of the pictures change from horizontal to vertical it leaves thin white lines behind on the background. Sometimes more and sometimes less and they disappear if you change the resize the browser but returns when the aspect changes again. I have attached a screen shot from your own demo site at Theme Forest.
Also, how can I remove the numbers under the pictures while viewing an album. I think I have to modify the .nyroModalCount but I'm afraid i don't know exactly how. As a temporary solution I have made them the exact colour of the background but I would like to remove them entirely.
Regards,
Staffan
About your main issue I don't think there is something that can be done(it is rather browser refresh issue) and I can't reproduce it on my iPad.
Your second issue http://support.apollo13.eu/discussion/comment/2497#Comment_2497 point 6 :-)
Concerning my main issue I think it's rather strange that you flatly state that there is nothing to be done about it. If I were a developer I would be concerned that my product doesn't display properly in a browser that has such a large user base, especially since Chrome is in your compatible browser list on Theme Forest.
And even if you can't reproduce it on your iPad doesn't mean that there isn't a problem.
Please try to reproduce it on a regular pc with a regular display to get a grasp of how bad this looks. I've tried to reproduce it myself in other browsers but it only occurs in Chrome.
If it is an issue that only I get, on my particular set up and computer, no one would be happier than me and I can let it go.
Regards,
Staffan
Maybe I didn't use right words(I am not native English speaker) but I DON'T say that for sure nothing can be done. I have seen such rendering issues for quite few years and I know that mostly they are not worth of time spending.
Sorry about iPad thing - I have misread this: Now I know you didn't mean turning phone/tablet around but changing to next photo/video. It was pure my mistake :-)
I will check it out soon, and will tell you about results.
I appreciate you looking into the rendering problem.
I removed the numbers from under the pictures, no problem, but this caused the caption for the images to be moved down a little bit too far. Is there a way to adjust for this so the text can be placed in it's original position?
Regards,
Staffan
You have to understand that such rendering engine issues is far from my powers as they are buried deep in chrome browser engine(chorme on iPad works OK - no lines, I don't have Mac so can't test there). I can only search for some workaround/trick to refresh this layout after switching to next image.
BUT :-) Two themes ago we had other quirk with safari browser which didn't work with base CSS behaviour. We spend week searching to fix it, made massive workaround for simple base thing, and as a result this base function turned out to be buggy thing that produced twenty topics here on forum. And no one even gave a **** about Safari.
That is why I tell that such issues is often not worth time spending cause result may become worse.
HOWEVER I will search for solution:-)
I understand it must be a pain getting the themes to work in all browsers and I appreciate you searching for a solution for this issue. I still like the theme a lot and it would be perfect if you managed to find a solution, that would most certainly earn you a 5 star rating from me over at Theme Forest. ;-)
Regards,
Staffan
Instead of previous CSS use this one: With regards.
Regards,
Staffan
I have spend some time trying to fix this white lines in Chrome browser but no luck. Anyway I see, that in new chrome lines are still visible, but they disappear right after animation is ended.
Sorry, but I really have no knowledge how to improve it :-(
