Hi
I have a Facebook "Like" button plugin on my site and it show up on my blogg post and pages but not on my Albums since its fullscreen bricks. So I was wondering if its possible to have a "Like" button after the FOLLOW Icon in the header or in the footer? I tried to upload a pic here but it takes for ever. Can link to it if you don´t understand me
Best Regards!
You can do it(in header) but it won't be safe modification(it will affect responsive layout).
I would advice you to use footer copyright text area - you can insert HTML there:-)
I tried to but it in the footer but it effects the copyright text in the way that you only see half of it. Can I switch the search button/area in the header to a like button?(just but HTML in that area instead of that search button?
Thank you for your answer!
Best Regards!
You can delete it and insert your code, but read my comment about unsafe change.
Didn´t work at all, the website didn't load at all. Is there a way to fix a higher footer in px. The Like button frame is 35px, and it mess up the text in the footer like I said before. So if I could make the footer just a little bit higher I think it would work?
Best Regards!
Use this custom CSS With regards.
But were do I put it? style.css did not work.
Best Regards!
Sorry for all the fuzz
Best Regards!
Use one option from three below:
1.child theme
2.plugin for Custom CSS
3.disable compressed CSS
I advise for 2.
check out the footer www.fotograftobias.se
Best Regards
Thank you so much!
Best Regards!
