I just downloaded the Hypershot theme and loving it! However, I don't need a logo and upon deleting the file from the settings, I now have this image with a "?" in the middle. How do I get rid of it altogether? Let me know please
Good, however having some kind of logo is good practise, cause users are used to this pattern that clicking in logo takes them back to homepage. I personally use this very often. I think there is possibility that some of your users will be confused and they will click social icons while searching for logo:-)
Yes, I think this is possible, it will just require extra time and thinking for user to realise that option :-) No worries - it is pure assumption from my side:-)
You can either change your logo to text as explained here http://support.apollo13.eu/discussion/comment/3519#Comment_3519 or just delete mentioned in topic line from
header.php
