Only found some info about changing width in the Airlock Theme. But I was wondering if its possible to get the blog layout a little wider. So is the a way to change the width?
I have read the hole doc of Hypershot and havent found any guides in how to change width in Classic blog style. If there is then am blind Can I change the CSS somewhere?
1. www.fotograftobias.se 2. Plugin: AJAX Thumbnail Rebuild Facebook Button Plugin Facebook Like Box Google Analytics for WordPress PC Custom CSS Tilt Social Share Widget Wordpress Facebook Like Plugin WordPress SEO WP-Copyright-Protection 3. Latest wordpress 4. hypershot 1.1.1 (havent update because I made some changes that will disable when updating) 5. I made this change in the CSS #footer { height: 35px; } 6. Ask if theres something else u wonder.
Do you know why we always(READ THIS) ask for live link to your installation? To help you faster:-)
Are you asking for Classic blog style, or Masonry? In Masonry you have option for full width, but you should deactivate sidebar then:-)
2. Plugin:
Facebook Like Box
PC Custom CSS
WordPress SEO
3. Latest wordpress
#footer {
height: 35px;
With Regards.
Wrrrr right click block - always make harder for debugging and live editing.
I see you use sidebar so this will be more changes. Also layout can be less responsive due to this changes. Add this custom CSS You can tweak it as you like.
