(Hypershot) Frontpage Slider Pictures/Thumbs align in a wrong way
edited April 2013 in Hypershot Posts: 40
Hey guys,
from time to time, the left most thumb on my frontpage (slider theme) doesn't align in the correct way (see the attached picture).
I am using Chrome on Win7, BUT it happens on IE and Fireox too.
Is there a fix anywhere out there?
Regards
Max
    Hello.
    Live link please, so maybe I will be able to recreate this issue.
    Here you go:
    http://bit.ly/ailoone
    Hello
    I have opened this link but all I could do is watch "Geduld, Geduld!" sign. Can you help me pass through it?
    Ahhhh. Sorry, maintenance Plugin was activated. My fault!
    Now ist should work!
    OK now it worked:-)
    I could see what you mean but only on Chrome. I will check it, but it looks like not easy to spot bug.
    I can see also that you use different height images (700 & 800px). You can try to unify it and check is issue still there. But I can see our demo also uses different height and I can't see bug there... :-|
    I think it is cause by loading of logo, cause before it loads header has different height and item taken different height. Anyway this is some clue, so hopefully fix will be available with next update:-)
  • edited April 2013 Posts: 40
    Yeah! The hint with the logo was good :)
    I added a fixed height in the css for #logo corresponding to the image dimensions:
    #logo { height: ??px }
    36px in my case.
    Thanks a lot!!
    Post edited by macmacs on
    Ooo nice! I like users like you ;-)
    I will work on it anyway :-)
    Great!
    And I like your theme, for it is very, very well structured and managable in a very intuitive way (child theme, plenty of theme options, ...).
    Keep on perfecting it!!
    Thanks a lot;-)
