from time to time, the left most thumb on my frontpage (slider theme) doesn't align in the correct way (see the attached picture). I am using Chrome on Win7, BUT it happens on IE and Fireox too.
I could see what you mean but only on Chrome. I will check it, but it looks like not easy to spot bug.
I can see also that you use different height images (700 & 800px). You can try to unify it and check is issue still there. But I can see our demo also uses different height and I can't see bug there... :-|
I think it is cause by loading of logo, cause before it loads header has different height and item taken different height. Anyway this is some clue, so hopefully fix will be available with next update:-)
Live link please, so maybe I will be able to recreate this issue.
http://bit.ly/ailoone
I have opened this link but all I could do is watch "Geduld, Geduld!" sign. Can you help me pass through it?
Now ist should work!
I added a fixed height in the css for #logo corresponding to the image dimensions:
#logo { height: ??px }
36px in my case.
Thanks a lot!!
I will work on it anyway :-)
And I like your theme, for it is very, very well structured and managable in a very intuitive way (child theme, plenty of theme options, ...).
Keep on perfecting it!!
