ok. attached is yours and mine. It seems the bottom benu on mine is pushing itself up over the image. That's my guess anyways. I'd loose the bottom menu but not sure how.
I think the small photos might have something to do with the footer menu being jacked up on the full albums. Not sure why it's like that. Can I email you the link?
There is also place for other menu, Footer short menu. As name suggest it should be as short as possible, for two max 3 short links like Faq, help, Sitemap etc.
As you said your footer menu is TOO BIG, so you have to change it.
I figured it out. I changed the settings in Menu. It was set to show the whole top menu at the footer. I created a separate footer menu and only put contact. Now it's fine. Thanks!
0. Iphone is small, so no wonder ;-)
1. Check how our demo looks on your iPhone http://themes.apollo13.eu/hypershot_dark/
2. post live link so I could see.
